10-28-2003 07:52 AM - edited 03-09-2019 05:18 AM
I'm trying to open Pix Device Manager this morning and receive the following error:
[ERR] pdm location 172.16.1.0 172.16.1.1 inside Invalid netmask: 172.16.1.1
Usage: pdm disconnect <session_id>
pdm history enable
pdm logging [<level> [<messages>]]
show pdm history [view {all|12h|5d|60m|10m}] [snapshot]
[feature {all|blocks|cpu|failover|ids|interface <if_name>|
memory|perfmon|sas|tunnels|xlates}] [pdmclient]
show pdm logging
show pdm sessions
clear pdm
clear pdm location
clear pdm logging
Command failed
pdm location 172.16.1.0 172.16.1.1 dmz
172.16.1.0 is my internal subnet
172.16.1.1 is my PIX inside interface
Any ideas?
thanks,
biz
Solved! Go to Solution.
10-28-2003 08:18 AM
Hi Biz,
As the error indicates you netmask in incorrect, for instance if you want a specific client on the inside to be allowed to open/use PDM then you'll need the following (example):
http server enable
http 192.168.1.10 255.255.255.255 inside
or for a range of clients then...
http server enable
http 192.168.1.0 255.255.255.0 inside
Makesure to save with command - write memory
Thanks -
10-28-2003 08:18 AM
Hi Biz,
http server enable
http server enable
Thanks -
10-28-2003 09:07 AM
It was actually my telnet. It had all kinds of funky entries I've never seen before... cleared it out and all is well... thanks.
