ESA with AMP integrate to CTR
fuhdan
I heard, that I can integrate every product where I have AMP enabled to the CTR Cloud.
Is that there a starting guide?
Thanks for any help
Marvin Rhoads
Are you using the Security Management Appliance (SMA) with your ESA deployment? That's a prerequisite for ESA integration with CTR as it provides the API capability. You also need to be running ESA 12.0 (or later).
If you have those, then refer to the following for details:
https://visibility.amp.cisco.com/#/help/module-sma
