Exact mechanics of alias command under 6.2
evan.moore
I'm trrying to understand a situation which has me puzzled. Part of the
problem is definitely not the fault of the PIX, but some of it might be. If
anyone can tell me an exact order of operations on packets as they
go through the PIX, and when (and how) the alias command is applied,
it might shed light.
Here's the problem:
PIX with outside, inside, and DMZ interfaces.
Mail server on the DMZ.
NAT suppressed between DMZ and inside to allow Windows NetLogin
service between a different server on the DMZ and a Windows PDC on
the inside.
DNS server on the inside LAN used by some of the clients on the
inside LAN.
DNS server on the outside LAN used by a different set of clients on
the inside LAN.
The behavior is thus:
With an
alias (inside) outside-ip dmz-ip 255.255.255.255
command in place, those clients that use the external DNS server
can connect to the mail server just fine. This fits exactly with the Cisco
tech note that describes the alias command. However, clients that
use the internal DNS server originate sessions with dmz-ip as the
destination address, and fail to connect.
I've changed the internal DNS server to reply with outside-ip rather
than dmz-ip, thus permitting all clients to connect, but I don't understand
why the PIX is not letting connections happen when the inside client
tries to connect directly to the dmz-ip address.
Can anyone explain this to me?
ERM
smahbub
Level 6
Level 6
I really don't think that the problem is with the PIX or the alias command. I don't see a problem while using A DNS server on the inside LAN that replies with the internal IP address. I do not think that the Alias command has any role to play here. In this setup neither does it DNat nor does it do DNS doctoring. Can your host directly ping the IP address of your server on the DMZ? I thing it will (remember to configure conduit for ping!) and that would indicate that things are working fine. I guess the problem really lies with DNS learning and not the alias command. If you are having problems pinging the server on your DMZ from the inside using its private adddress, then you need to check your routing information.
I forgot to spell out the reverse case, which helps show the problem even
better.
If I remove the alias command from my PIX, then those clients using
the internal DNS server try to connect to the dmz-ip (this is before I
changed the internal DNS) and do so fine. Those clients using the
external DNS, thus trying to connect to the external-ip of the server,
fail to connect.
Thus, the alias command is needed, to allow the clients using the
external DNS servers to contact the mail server correctly. While I
agree that those clients should be changed to use the internal DNS
server, that's not something which can be done quickly.
ERM
