failover after command show isakmp sa det
zroth
Hi all,
we have PIX 515E in failover configuration.After upgrade to version 6.3.(4) I have noticed a strange
thing.When I use command show isakmp sa det, a failover happens.With the same command without option
detail all works fine.
I must say I did not use the command with this option before,but with another PIX 515E failover system running version 6.3.(3) there is no problem
with option det.
Has anybody the similar experience ? Or is it a known version bug ?
Sincerely
Zdenek
drolemc
Level 6
Level 6
Thats suprising. Is it possible that you are facing memory issues? See if your PIX is overloaded, had too many configuration lines or simply too little memory.
