firewall problem
Mohammed Gomaa
Visitor
dears,
can i Add secondary ip address to 506 firewall interface to support two different network
Patrick Iseli
Level 11
Level 11
No this is not possible on the PIX Firewall.
You need an internal router to that or you can configure VLANs to a layer 3 capable Switch.
sincerely
Patrick
m.sir
Level 11
Level 11
PIX 506 doesnt support secondary Ip, but you can use trunk with dot1q encapsulation
try following document Using VLANs with the Firewall:
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a0080172786.html#wp1113411
M.
Hope that helps, rate if it does
