fixup protocol
znair
Community Member
How can i open port 450 on the pix 525 firewall running 6.1 (3) code
tserver 450/tcp
Computer Supported Telecomunication Applications
regards
anair
bfl1
Level 5
Level 5
What do you mean "open" a port? Are you wanting to allow access to the port from the outside or inside?
If from the outside, create a static for the server they will be accessing and then add the desired port to your in bound ACL.
shannong
Level 9
Level 9
Fixups are application layer intelligence about specific protocols.
What you need is a access-list entry in your ACL for the outside, outside-acl in my example. Assuming there is a server at private address X on the inside, and you want to access it from the outside using address Y. You would need something like this:
static (inside,outside) Y X netmask 255.255.255.255
access-list outside-acl permit tcp any host Y eq 450
You'll need to clear the translation for that host if you're adding the static statement as part of this new configuration.
clear xlate local X (X is the server address)
-S
znair
Community Member
Thanks..
It worked
regards
znair,
When someone provides a working solution for you, you should reward him by giving him the points for correcting your problem......
