Forwarding rule
sethuraman.a
I have 2 questions. firstly, I am using a static map to forward the packets from DMZ to inside network. Is there any other way to do this ?
Secondly , Can i use static NAT to 2 IP address from the inside network to Single IP address in the DMZ network. If so, what commands do i use ?
yusuff
Q1.
The only way to forward traffic from DMZ to inside is by creating a static translation using the static command. Note that traffic from lower level interface to a higher level interface eg from DMZ to Inside, you must have a static.
http://www.cisco.com/warp/public/707/28.html
Q2.
No, you cannot have 2 inside IP addresses assigned to a single IP on DMZ.
R/Yusuf
