Bookmark
Subscribe
263
fwsm 2.2
emily
Recently , I test fwsm 2.2 with transparent context and MSFC inside , i found inside of protect server that didn't any static map just only used access-list,then outside user can ftp or www connect inside server , that diff other pix 500 appliance which need static and access-list
i want to confirm is true ?
irelandsky
if you have enabled the "same-security-level permit inter interface" command, all the interface on the FWSM with the same Security ID don't need of the static command ( so nat is not required)
Older release and the pix 500 family require nat from high security int to lower sec interface
Hope this is helpfull for you
Ciao
Marco
Hello
Thanks for you reponse , i didn't used "same-security-level permit inter interface" , that just only used access-list , the outside user then can connect to inside server , configure same as URL:http://www.cisco.com/en/US/products/hw/switches/ps708/products_module_configuration_guide_chapter09186a00802010bd.html example 5
whether or not need to configure static map for inside server ?
