FWSM Blades Contantly running diagnostics.
Patrick Laidlaw
Level 4
Level 4
Hey I was wondering if this was normal for two FWSM blades to keep doing diagnostics over and over. It does this about every four hours.
Aug 18 10:56:24.957 AST: SP: The PC in slot 3 is shutting down. Please wait ...
Aug 18 10:56:25.121 AST: SP: PC shutdown completed for module 3
Aug 18 10:56:25.121 AST: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (Reset)
Aug 18 10:58:03.878 AST: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimum Diagnostics...
Aug 18 10:58:06.526 AST: %DIAG-SP-6-DIAG_OK: Module 3: Passed Online Diagnostics
Aug 18 10:58:16.717 AST: %OIR-SP-6-INSCARD: Card inserted in slot 3, interfaces are now online
Aug 18 15:07:37.304 AST: SP: The PC in slot 4 is shutting down. Please wait ...
Aug 18 15:07:37.459 AST: SP: PC shutdown completed for module 4
Aug 18 15:07:37.467 AST: %C6KPWR-SP-4-DISABLED: power to module in slot 4 set off (Reset)
Aug 18 15:09:16.618 AST: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimum Diagnostics...
Aug 18 15:09:19.210 AST: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
Aug 18 15:09:29.542 AST: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
Patrick
grant.maynard
Level 4
Level 4
This is not normal. What chassis & s/w versions do you have?
I was pretty sure that it was not normal. We are using it on a 6513 FWSM 2.3(3). We are looking at upgrading to 3.1. Although I need to check something else just found out that we had a 6748 blade die on us in that chassis so I guess I have more issues to resolve.
Patrick
yes, I'd check the chassis and supervisor out, I don't think it's a FWSM problem.
