FWSM problem
bhatia.sachin
im not able to access my exchange server.
im new to FWSM an suspect the issue there.i give sh int on FWSM an get the following msg for all the vlans in my domain
Interface vlan20 "", is administratively down, line protocol is up
Available for allocation to a context
If i try to enable the interface it gives me the followin error
FWSM(config)# int vlan 20
Unknown interface vlan.
can someone help....
mehrdad
Level 3
Level 3
I think you should enable that VLAN interface as following :
Router(config)# interface vlan vlan_number
Router(config-if)# no shut
not at FWSM module config mode.
VLANs need to be assigned to FWSM from the Sup as follows.
Native IOS:
firewall vlan-group x 20
firewall module vlan-group x
Hybrid IOS:
set vlan 20 firewall-vlan
Shijo George.
