GRE Tunnel protection and qos pre-classify
vzufferey
How to apply QoS on GRE/IPSec tunnels when the GRE tunnels are encrypted using the "tunnel protection ipsec profile" command? Cisco documentation "QoS for VPN" says pre-classify command have to be appy in tunnel interface AND in crypto-map. With GRE tunnel protection I don't have any crypo-map configured. I can apply pre-classify ony in tunnel interface... How works the QoS process with this configuration?
router#sh run brief
crypto pki certificate chain ca
certificate 00B6
certificate ca 01
crypto isakmp policy 10
encr 3des
group 5
crypto ipsec transform-set uset esp-3des esp-sha-hmac
crypto ipsec profile u-ipsec
set transform-set uset
set pfs group5
policy-map child
class class-default
fair-queue
policy-map qos_shaping
class class-default
shape average 200000
service-policy child
interface Tunnel140162
ip unnumbered Loopback1
service-policy output qos_shaping
qos pre-classify
tunnel source GigabitEthernet0/2.12
tunnel destination 172.16.16.2
tunnel protection ipsec profile u-ipsec
router#sh crypto map
Crypto Map "Tunnel140162-head-0" 65537 ipsec-isakmp
Map is a PROFILE INSTANCE.
Peer = 172.16.16.2
Extended IP access list access-list permit gre host 172.16.9.20 host 172.16.16.2
Current peer: 172.16.16.2
PFS (Y/N): Y
DH group: group5
Transform sets={
uniset,
dmitry
The service-policy output qos_shaping should go to the physical intf. the Tunnel140162 uses. In this case the policy-map will be able to see the tunnel's payload before encryption. You can leave the service-policy on the tunnel as it is now and do not have to use qos pre-classify, the only condition for MQC in this case: it has to be parent-child with the shaping in parent, otherwise it won't be configured on Tunnel.
