Having problems getting NAT communications to work.
ssheil
I have gone through the docs in creating a static NAT.  I have gone into firewall/NAT Rules and set the internal / external entries, set access rules for the various services.  However, I am unable to make a connection remotely.  Somewhere along the line, I must be missing a command or something.  Any advise would be appreciated.
ASA ver: 8.4(4)
ASDM ver: 6.4(9)
Jennifer Halim
Pls share your current config, and also what you are trying to achieve. Real IP and NATed IP that you are trying to make remote connection would help. And also assuming that you are trying to RDP and remote desktop has been enabled on the host that you are trying to connect remotely?
