07-03-2002 11:28 AM - edited 02-20-2020 09:18 PM
Cut these items from a PIX that I'm working on. I can't decifer what they are.
access-list acl_in permit 23 host xxx.253.5.3 host 10.10.1.10
access-list acl_in permit 23 host xxx.253.5.3 host xxx.253.5.4
access-list acl_in permit ip any any
First, what is protocol 23?
Second, doesn't the last statement allow the protocol from any net to any net making the need for the first two lines redundant (I'm guessing that the last line was supposed to say deny).
07-03-2002 12:14 PM
the last statement will override the first two, if no one of the first two matches , the last one will do.
by default PIX deny everything, so you dont need the deny ip any any as the last directive.
permit ip any any is turning your firewall to an ethernet patchcord =)
and, IP as protocol implies all others.
If you want the get a list of protocol numbers go to
http://www.iana.org/assignments/protocol-numbers
regards
07-05-2002 10:31 AM
I had looked at the protocol table before and here's what it says about 23....
23 TRUNK-1 Trunk-1 [BWB6]
Which really doesn't tell me much. Someone else suggested that perhaps they were really trying to allow telnet access from the router into the PIX which would make sense...
