08-04-2001 10:14 PM - edited 03-08-2019 08:33 PM
I have PIX 515 ver 5.1 with six interfaces. I have to allow a network on one of the interfaces to inside of my network. Do i use NAT or should I use static/conduit. Please advice also appr. if u could provide with sample config.
08-06-2001 09:17 AM
Either an access list (Cisco preferred) or a conduit. I generally use statics to map specific hosts
from one security level to another. Are allowing the entire low security subnet to access the high
security subnet ? or just specific hosts ?
08-13-2001 09:14 AM
You can use a static command:
static (inside,DMZ1) 10.0.0.0 10.0.0.0 netmask 255.0.0.0 0 0
This will allow you to access from the Low directly to the High.
