How to add a filter to signiture?
cbergel
A specific host allways attack to our network.This host is using DNS Server.We don't want this to be detected as an attack.How to add a filter to this signiture?
signiture id 4003 "Nmap UDP Port Sweep"
shawn.posthumus
Heres one way:
log into your sensor via ssh
sensor#conf t
sensor#service alarm-channel-configuration virtualAlarm
sensor#tune-alarm-channel
sensor#EventFilter
sensor#Filters DestAddrs Exception False SIGID 4003 SourceAddrs SubSig *
sensor#exit
sensor#exit
save changes when prompted.
thank you very much.
garyprice
are you using a network IDS sensor. Like a Cisco-K9-4235? If so I can detail the very simple process to filter "out" the source from detection from the signature 4003
