09-06-2018 07:03 AM - edited 03-10-2019 01:05 AM
Good morning:
We are trying to solve an issue with a vendor however for them to move forward they as asking for a PCAP that shows EAPoL occur. I have taken multiple pcaps and unable to find this within the PCAP. I have read other blogs/posts that state using a HUB between the device and switch is probably the best approach but finding a hub these days in nearly impossible.
To give you some insight we are using ISE/Radius for Authentication Server --- WS-C3560CX-8PC-S Switch for the Authenticator and the end point/client.
Here is a snippet of the port config:
switchport access vlan X
switchport mode access
switchport voice vlan Y
no logging event link-status
srr-queue bandwidth share 1 30 35 5
priority-queue out
authentication event fail action next-method
authentication event server dead action authorize vlan X
authentication event server dead action authorize voice
authentication event server alive action reinitialize
authentication host-mode multi-domain
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication violation restrict
mab
snmp trap mac-notification change added
no snmp trap link-status
mls qos trust cos
dot1x pae authenticator
auto qos trust
spanning-tree portfast edge
ip dhcp snooping information option allow-untrusted
end
Any help / direction is very much appreciated.
Ty,
-Rob
Solved! Go to Solution.
09-06-2018 09:12 AM
WOW. We got it and had to use a NON Company Laptop Asset. I wonder if there was some type of filtering unbeknownst to us...anyconnect?
Ha I don't know what prompted my colleague to use his own personal laptop but thank goodness he did.
I can clearly see the EAP packets.
We are good to go!
Thanks guys!
-Rob
09-06-2018 07:27 AM
09-06-2018 07:43 AM
TY! I appreciate the reply!
So in this case we are capturing from the supplicant to the authenticator. So (at least in my mind) we would see the EAP success but understandly not see the 4 way handshake But yes we are doing exactly we you stated below with regards to capurting on the access port.
09-06-2018 07:48 AM
09-06-2018 08:04 AM
I agree with you but we are not seeing that. And yes, that cmd is enabled globally.
09-06-2018 08:12 AM
09-06-2018 08:40 AM
This is a phone. To make a long story short we are seeing somtimes the client fail dot1x authentication and we need to show them vendor happening in real time. They need a pcap showing EAPoL.
Yes and these clients authenticate and succeed dot1x authentiction.
(for protection i'm going to cover some stuff up)
S-ISE#sho auth sess int gi0/3 details
Interface: GigabitEthernet0/3
MAC Address: aaaa.bbbb.cccc.dddd
IPv6 Address: Unknown
IPv4 Address: x.x.x.
User-Name: xxxxx
Status: Authorized
Domain: VOICE
Oper host mode: multi-domain
Oper control dir: both
Session timeout: N/A
Restart timeout: N/A
Periodic Acct timeout: 172800s (local), Remaining: 102554s
Session Uptime: 70285s
Common Session ID: 0AC0015000000239D2A32386
Acct Session ID: 0x00000D94
Handle: 0x0200013D
Current Policy: POLICY_Gi0/3
Local Policies:
Service Template: DEFAULT_LINKSEC_POLICY_SHOULD_SECURE (priority 150)
Security Policy: Should Secure
Security Status: Link Unsecure
Server Policies:
Method status list:
Method State
dot1x Authc Success
09-06-2018 07:36 AM
I would utilize port mirroring i.e SPAN. A basic SPAN, such as below relays all packets from the source to the destination where you would plug a device running TCPDUMP or wireshark.
monitor session 1 source interface Gi1/0/1
monitor session 1 destination interface Gi1/0/2
Have a read of the below as RSPAN and ERSPAN might be appropriate in addition to SPAN (local).
09-06-2018 09:12 AM
We are good to go!
Thanks guys!
-Rob
07-25-2019 12:19 PM
I had the same issue. once i removed the anyconnct mobility client from the laptop running wireshark I was able to see the EAP and EAPoL packets
