10-08-2007 11:28 AM - edited 03-09-2019 06:59 PM
I was wondering how can i create accounts for remote users to be able to vpn please ? I have setup the vpn server successfully.
Regard,
10-09-2007 06:47 AM
Did you mean
username SuperUser secret SuperPassword
10-09-2007 11:54 AM
Yes but i wanna make sure that remote user's won't have access to the router/be able to telent to the device at all
10-09-2007 12:22 PM
Hello.
I believe that you can try this:
Router# configure terminal
Router (config)# password encryption aes
Router (config)# crypto ipsec client ezvpn ezvpn1
Router (config-crypto-ezvpn)# username server_1 password 0 blue
if you are using easy vpn.
from: http://cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455b7d.html
10-17-2007 05:57 AM
Thanks for the info.
I actually created the account on the router and saved the config, however authentication failes when connecting remotely.
When i connect once i enter the username and password..it keeps prompting me for the password.
any idea
