How to evaluate alarms?
pheuch
As I started working with netranger one of my first problem was, that the sensor is logging the attack signature, but not the answer of the attacked server. We are currently configured the sensor that it will create an iplog for most signatures at level 4 and 5. While evaluating the alarms, we download the iplogs and check what happened.
Is there a better way to do this ? If not, may I suggest to include the answer of the server to the signature event data for future versions?
mhossain
The only way that you may view responses from the server is to use the ip logs in the manner in which you are doing this.
-Mun
