How to Fix SSH_EVENT_RESPOVERFLOW on FMC
Garry Cooper
I am trying to transfer legitimate traffic using openssh verison 8.1 and the IPS triggers SSH_EVENT_RESPOVERFLOW.
What is the best option to fix this, as I am reluctant to disable rule, and whitelisting does not work
Ilkin
The SSH_EVENT_RESPOVERFLOW could be shown because the SSH preprocessor is enabled that also has the option Detect Challenge-Response Buffer Overflow Attack enabled. From the documentation:
Enables or disables detecting the Challenge-Response Buffer Overflow exploit.
You can enable rule 128:1 to generate events and, in an inline deployment, drop offending packets for this option. Note that an SFTP session can occasionally trigger rule 128:1.
According to the documentation for SFTP traffic, it seems to be expected.  Is there SFTP traffic going through Snort?
Thanks for the reply, I have pushed this back to the vendors, as I suspect they could be using an old version of openssh.
Will update this once I know
