How to make port redirection work?
devildoc
If anyone can help me with this, then i would appreciate it.
I have a 515E PIX with 3 interfaces and IOS 6.2. I am trying to configure port redirection for one of my internal servers but it does not work. See the below configuration.
static (inside,outside) tcp x.x.x.1 smtp 10.10.10.1 smtp netmask 255.255.255.255 0 0
static (inside,outside) tcp x.x.x.1 pop3 10.10.10.2 pop3 netmask 255.255.255.255 0 0
static (inside,outside) tcp x.x.x.1 www 10.10.10.2 www netmask 255.255.255.255 0 0
static (inside,outside) x.x.x.3 10.10.10.3 netmask 255.255.255.255 0 0
static (inside,outside) x.x.x.4 10.10.10.4 netmask 255.255.255.255 0 0
static (inside,outside) x.x.x.5 10.10.10.5 netmask 255.255.255.255 0 0
access-list 101 permit tcp any host x.x.x.1 eq smtp
access-list 101 permit tcp any host x.x.x.1 eq pop3
access-list 101 permit tcp any host x.x.x.1 eq www
access-list 101 permit tcp any host x.x.x.3 eq telnet
access-list 101 permit tcp any host x.x.x.4 eq ftp
access-list 101 permit tcp any host x.x.x.5 eq https
access-group 101 in interface outside
With the above configuration, only the smtp ACLS statement works (I could telnet to port 25), but the rest of the port redirection statement don't work. If i removed the smtp statement, then all of the port redirection work (i could telnet to ports 110 and 80). Anyone knows why that is the case? Thanks.
JD
5 Replies 5
gfullage
That doesn't sound normal? Can you provide syslogs of when you try and telnet to the pop3 and www ports, that may show us a bit more about what's going on?
how can i enable syslogs for those sessions?
You can't really enable it specifically for those sessions. Just do:
logging on
logging console debug
term mon
although be careful if this is a busy PIX, you'll get tons of messages. Then try telnet'ing to one of those ports and see what messages come up.
gfullage
Actually, can you send us your PIX config (remove the password lines and change your public IP addresses), this may tell us what's going on.
Ok. So here is the pix configuration that i used. Thanks.
PIX Version 6.2(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
no names
access-list 101 permit tcp any host 63.100.100.5 eq 3389
access-list 101 permit udp any host 63.100.100.5 eq 3389
access-list 101 permit tcp any host 63.100.100.9 eq smtp
access-list 101 permit tcp any host 63.100.100.9 eq pop3
access-list 101 permit tcp any host 63.100.100.9 eq www
access-list 101 permit tcp any host 63.100.100.9 eq lotusnotes
access-list 101 permit udp any host 63.100.100.9 eq domain
access-list 101 permit tcp any host 63.100.100.50 eq www
access-list 101 permit tcp any host 63.100.100.50 eq https
access-list 101 permit tcp any host 63.100.100.80 eq www
access-list 101 permit tcp any host 63.100.100.80 eq https
access-list 101 permit tcp any host 63.100.100.90 eq https
access-list 101 permit tcp any host 63.100.100.101 eq citrix-ica
access-list 101 permit tcp any host 63.100.100.102 eq citrix-ica
access-list 101 permit icmp any any echo
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any source-quench
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any time-exceeded
access-list 105 permit tcp any host 10.10.10.10 eq domain
access-list 105 permit udp any host 10.10.10.10 eq domain
access-list 105 permit tcp any host 10.10.10.17 eq 8080
access-list 105 permit tcp any host 10.10.10.17 eq citrix-ica
access-list 105 permit tcp any host 10.10.10.18 eq 8080
access-list 105 permit tcp any host 10.10.10.18 eq citrix-ica
access-list 105 permit tcp any host 10.10.10.50 eq www
access-list 105 permit tcp any host 10.10.10.50 eq https
access-list 105 permit tcp any host 10.10.10.50 eq domain
pager lines 24
logging on
logging timestamp
logging console alerts
logging monitor notifications
logging buffered notifications
logging trap informational
logging history notifications
logging host inside 10.10.10.50
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 100full
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside 63.100.100.1 255.255.255.0
ip address inside 10.10.10.1 255.255.255.0
ip address dmz 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
failover ip address dmz 0.0.0.0
pdm location 10.10.10.17 255.255.255.255 inside
pdm location 10.10.10.12 255.255.255.255 inside
pdm location 10.10.10.18 255.255.255.255 inside
pdm location 10.10.10.50 255.255.255.255 inside
pdm location 192.168.1.90 255.255.255.255 dmz
pdm location 10.10.10.10 255.255.255.255 inside
pdm location 63.100.100.20 255.255.255.255 outside
pdm location 192.168.1.80 255.255.255.255 dmz
pdm location 63.100.100.10 255.255.255.255 outside
pdm logging warnings 100
pdm history enable
arp timeout 14400
global (outside) 1 63.100.100.201-63.100.100.253 netmask 255.255.255.0
global (outside) 1 63.100.100.254
nat (inside) 1 10.10.10.0 255.255.255.0 0 0
nat (dmz) 1 192.168.1.0 255.255.255.0 0 0
static (inside,outside) tcp 63.100.100.9 smtp 10.10.10.7 smtp netmask 255.255.255.255 0 0
static (inside,outside) tcp 63.100.100.9 pop3 10.10.10.12 pop3 netmask 255.255.255.255 0 0
static (inside,outside) tcp 63.100.100.9 www 10.10.10.12 www netmask 255.255.255.255 0 0
static (inside,outside) tcp 63.100.100.9 lotusnotes 10.10.10.12 lotusnotes netmask 255.255.255.255 0 0
static (inside,outside) udp 63.100.100.9 domain 10.10.10.12 domain netmask 255.255.255.255 0 0
static (inside,outside) 63.100.100.5 10.10.10.10 netmask 255.255.255.255 0 0
static (inside,outside) 63.100.100.50 10.10.10.50 netmask 255.255.255.255 0 0
static (inside,outside) 63.100.100.101 10.10.10.17 netmask 255.255.255.255 0 0
static (inside,outside) 63.100.100.102 10.10.10.18 netmask 255.255.255.255 0 0
static (dmz,outside) 63.100.100.80 192.168.1.80 netmask 255.255.255.255 0 0
static (dmz,outside) 63.100.100.90 192.168.1.90 netmask 255.255.255.255 0 0
static (inside,dmz) 10.10.10.10 10.10.10.10 netmask 255.255.255.255 0 0
static (inside,dmz) 10.10.10.12 10.10.10.12 netmask 255.255.255.255 0 0
static (inside,dmz) 10.10.10.17 10.10.10.17 netmask 255.255.255.255 0 0
static (inside,dmz) 10.10.10.18 10.10.10.18 netmask 255.255.255.255 0 0
static (inside,dmz) 10.10.10.50 10.10.10.50 netmask 255.255.255.255 0 0
access-group 105 in interface dmz
route outside 0.0.0.0 0.0.0.0 63.100.100.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.10.10.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 dmz
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt noproxyarp inside
no sysopt route dnat
telnet 10.10.10.0 255.255.255.0 inside
telnet 192.168.1.0 255.255.255.0 dmz
telnet timeout 15
ssh timeout 5
terminal width 80
:end
