How to silently install CSA using .wsf script
monica.mckee
I created an agent kit that does a quiet install, so it doesn't prompt the user, but it does display a couple of status boxes. It is possible to do a completely silent install? The config guide indicates that it can be done but doesn't give an example. I'm using the command "oExec = wshShell.Run ("CSA-setup.exe", 0, true)" in a .wsf file, where CSA-setup.exe is the agent kit file from the CSA MC.
sbilgi
Level 5
Level 5
I guess you could created an agent kit from a group that has "no user
intervention" selected, and then use a software distribution tool to
drop the package in and the user would never know that CSA is on and
enforcing rules.
rene-rise
You should be able to write
CSA-setup.exe /s --autolevel=1 --noreboot=1
Read more here:
http://www.cisco.com/en/US/customer/products/sw/secursw/ps5057/products_qanda_item09186a008049ad72.shtml#qa15
