05-02-2003 04:18 AM - edited 03-09-2019 03:07 AM
As default every traffic from inside to outside is allowed and from outside to inside is blocked in PIX. I try to allow only http, https and ftp traffic from inside to outside. After changing I cant access to internet. I am using PIX 506.
Does my access-list miss some thing?
access-list 120 permit tcp any any eq 80
access-list 120 permit tcp any any eq 443
access-list 120 permit tcp any any eq 21
access-group 120 in interface inside
05-02-2003 05:12 AM
DNS is currently not allowed through your firewall. Unless you are defining explicit destination IP addresses, your web browser/ftp client cannot resolve the FQDN to an IP address. You need to allow outbound DNS from your internal DNS server or internal hosts to a DNS server(s) on the outside.
05-02-2003 06:19 AM
Thanks for reply;
can you please give me some more detail, How can allow DNS for lookup?
05-02-2003 01:04 PM
You need to also allow tcp/53 and udp/53 going outbound via ACL 120. Add something like the following lines to ACL 120
access-list 120 permit tcp any any eq 53
access-list 120 permit udp any any eq 53
I believe lookups only use udp/53, but I'm not positive.
