Https problem
ayoussef82
Level 3
Level 3
Dear sir,
i activated a tunnel between 2 sides but there is a problem appeared where any application depend on https (mail) dosen't work between the 2 sides.
Kindly find here under the tunnel configuration:
Hellioplis Side:
interface Tunnel2
ip address 10.50.2.1 255.255.255.252
tunnel source Serial0/0/0.60
tunnel destination 192.168.2.2
ip route 10.1.2.0 255.255.255.0 10.50.2.2
Evergreen Side:
interface Tunnel0
ip address 10.50.2.2 255.255.255.252
tunnel source Serial0/0.1
tunnel destination 192.168.2.1
ip route 10.1.5.0 255.255.255.0 10.50.2.1
spremkumar
Level 11
Level 11
Can you revert the mtu size set on both the tunnel interface ??
also have u configured any ip tcp-adjust mss parameters on any of the tunnels ??
regds
yes i can, but there is no change in case
