I am not able to config IPS in Cisco packet tracer
vinuthatr1996
Hi All,
I am getting an error in running the configuration command for IPS
I have no problem till creating a directory name ipsdir
post that not  able to Configure the IPS signature storage location.
Anyone plz help here.
You need to be in conf t you was not
You need to run the command
conf t
  ip ips ....
Hello @vinuthatr1996
   First you need to enable the securityk9 license on your router.
For router c1900
license boot module c1900 technology-package securityk9
For router c2900
license boot module c2900 technology-package Securityk9
 You need to reload the router
Then, you need to be in "conf t" mode
conf t
Router(config)#ip ips ?
config Location of IPS configuration files
fail Specify what to do during any failures
name Specify an IPS rule
notify Specify the notification mechanisms (SDEE or log) for
the alarms
signature-category Signature Category
signature-definition Signature Definition
Hi @Flavio Miranda
I have already enabled the securityk9 on router c2900.
Created the ipsdir
Into configuration mode
Post that configuration command
Ip ips config location flash:ipsdir
There i m getting ths error
conf t
  ip ips ....
Thank you.
It worked.
