icmp problem on 515E
nki
internet---r1--pix---r2--3512---lan.
We are able to ping from lan ( high level ) to the Internet , but outside host ( low lever) ,and from muy r1 could nt ping neither to inside pix nor lan.
my access-list is configured to allow icmp traffic from outside to LAN.
Here is my pix inmput:
IX Version 6.3(4)
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 100full
interface ethernet3 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
nameif ethernet3 dmz2 security10
enable password encrypted
passwd encrypted
hostname Pix515
domain-name
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 102 permit icmp any any echo-reply
access-list 102 permit icmp any any source-quench
access-list 102 permit icmp any any unreachable
access-list 102 permit icmp any any time-exceeded
access-list 102 permit icmp any host 192.168.1.2 echo
pager lines 24
logging on
logging buffered errors
logging trap debugging
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu dmz2 1500
ip address outside 192.168.1.1 255.255.255.0
ip address inside 172.16.1.1 255.255.255.0
ip address dmz 172.16.128.1 255.255.255.0
no ip address dmz2
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address dmz
no failover ip address dmz2
pdm history enable
arp timeout 7200
global (outside) 1 192.168.1.50-192.168.1.253
global (outside) 1 192.168.1.254
nat (inside) 1 10.0.0.0 255.255.255.0 0 0
access-group 102 in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.1.2 1
route inside 10.0.0.0 255.255.255.0 172.16.1.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa-server tacacs+ protocol tacacs+
aaa-server tacacs+ max-failed-attempts 3
aaa-server tacacs+ deadtime 10
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
crypto ipsec security-association lifetime seconds 2700
telnet 172.16.1.2 255.255.255.255 inside
telnet 192.168.1.2 255.255.255.255 inside
telnet 10.0.0.2 255.255.255.255 inside
telnet 10.0.0.3 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3000
dhcpd ping_timeout 750
dhcpd domain
dhcpd auto_config outside
terminal width 80
Cryptochecksum:: end
Pix515#
Thanks in advance
sig
Federico's post should help you configure the statics. Also when I meant "from outside to inside you will need a public IP" I really meant from the internet.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
11 Replies 11
thisisshanky
Level 11
Level 11
Where are the static commands. You cannot ping from outside to inside without using a public IP. Or else the host on the internet has to use VPN to the PIX and then ping the host behind r2.
Sankar Nair
Hei
With this access-list as I have read , I could ping from r1 to Lan.
how should configure static commands in order to ping from r1 to lan ???
thanks thisisshanky
Sankar Nair
Hello :
See this document
http://www.cisco.com/warp/public/110/31.html
As an example you can try this :
You will not be able to ping from the outside with your present configuration.
What you can do is try the following configuration.
The "static" statements will allow you to map two global IP addresses to your inside router IPs.
First static will map the global ip 192.16.1.3 to (r2:172.16.1.2) and the second "static" will map the global ip 192.168.1.4 to the IP address of r2 on network 10.0.0.0.
static (inside,outside) 192.168.1.3 172.16.1.2 netmask 255.255.255.255 0 0
static (inside,outside) 192.168.1.3 10.0.0.1 netmask 255.255.255.255 0 0
access-list ACL-INBOUND permit icmp any host 192.168.1.3 echo
access-group ACL-INBOUND in interface outside
Let me know how it goes.
Sorry for the typo , the scond statement has 192.168.1.4 for the global IP
static (inside,outside) 192.168.1.4 10.0.0.1 netmask 255.255.255.255 0 0
Hei
access-list 102 permit icmp any host 192.168.1.3 echo
access-list 102 permit icmp any host 192.168.1.4 echo
I still could nt ping to my LAN
access-group ACL-INBOUND in interface outside#access-group 102 in interface outside
Are you pinging from R1 to lan or from the internet ?
Sankar Nair
Hei
I am pinging from R1 , not From Internet.
I want to have connection between Router r1 and all devices in LAN , r2 and inside pix
Hello :
Well this is just a workaround . a parcial solution . With the configuration I posted previously you should ping 192.168.1.3 and 192.168.1.4 and get a response without a problem.
In order to do what you request , you will have to map every local (inside) address to a global (outside) address , which is very unpractical.
Please read this document.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
With your config, you should only be able to ping 172.16.1.2 and 10.0.0.1 (192.168.1.3 and .4) . Like Federico suggested you will have to have one to one mapping which does not sound like a feasible solution.
Sankar Nair
That`s correct , to ping to 172.16.2.1 , I have to use it`s mapping ip address 192.168.1.3 ( I see it from debug icmp trace .)
Thanks for your succefull help.
It`s not possible to ping direct to lan ip addresses from outside pix ???
