IDS 4210 Blocking using ACL on a router
b-krigeris
I am having trouble configuring blocking. I followed all of the parameters on CSPM i.e. router telnet and enable passwords, interface, ip address. When I try to apply blocking, CSPM tells that the block is successful, but when I check
/usr/nr/var/errors.managed file I get the following errors:
Router(config)#
01/23/2002 15:01:25UTC E Connection lost to net device 10.60.4.1
01/23/2002 15:01:28UTC E Established a connection to 10.60.4.1
01/23/2002 15:01:29UTC E Error: Syntax error from invalid input at device [Cisco] IP [10.60.4.1] state [Active]
Text from device:
no ip access-list ext IDS_Ethernet0_in_0
% Invalid input detected at '^' marker.
I can't figure out what causes the error.
7 Replies 7
stleary
What version of IDS are you running? There were
several bugs in earlier versions that could cause
this, which have all been fixed in the latest release.
What seems to be happening is that the sensor
is unable to configure the router for blocking.
The router is not in the correct mode for
configuration when the sensor sends the
'no ip ...' command, which causes a syntax error
and loss of communication with the router. No
hosts can be blocked until this is resolved. A
correctly configured sensor should never cause
syntax errors at the router.
Sean
I am running 3.0(3)S13
Boris.
The IDS version should be OK.
The best way to proceed would be if you can open a TAC case.
Tell the TAC person to contact me at stleary@cisco.com
Provide the TAC person with these files from your sensor:
/usr/nr/managed.conf
/usr/nr/var/errors.managed.* ( just one error file should be enough)
Also, capture the output of the 'nrvers' command on your sensor and
capture the output of the 'show config' command on the router.
If you can, it would be very helpful if you could capture some snoop output
at your sensor. Here are directions for doing so:
As root on the sensor
snoop -d -o /tmp/packets.snoop
Then as netrangr do an nrstop and an nrstart on the sensor. Wait about
two minutes for the syntax error to occur, and then terminate snoop.
Example:
snoop -d iprb0 -o /tmp/packets.snoop 10.1.1.1 10.1.1.3
-d iprb0 is the IDS-4230 command and control interface
-o /tmp/packets.snoop says to save the binary packets in the
/tmp/packets.snoop file
10.1.1.1 is the sensor ip
10.1.1.3 is the router ip
I got it working on a 3620 router. My several failed attemps were on a 1605R router.
Can you tell me what IOS version is running on the 1605R?
I will see if the problem can be recreated in our lab.
Router>sh ver
IOS (tm) 1600 Software (C1600-Y-M), Version 11.2(18)P, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Mon 12-Apr-99 15:29 by ashah
Image text-base: 0x02005000, data-base: 0x0232C82C
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
ROM: 1600 Software (C1600-RBOOT-R), Version 12.0(3)T, RELEASE SOFTWARE (fc1)
Router uptime is 5 days, 23 hours, 41 minutes
System restarted by reload
System image file is "c1600-y-mz.112-18.P", booted via flash
The IOS version also looks OK.
Two more possible causes, if you ever try to block from the 1605R in the future:
- Make sure that the shun interface names are spelled correctly, and match
interfaces on the router. However I don't think this was the cause, since it
should result in a different error message.
- Do not enter config mode on the router from a telnet session or terminal server
session while the router is being controlled by the sensor. This has been found
to sometimes cause errors on 1605's in our lab.
If you run into this problem again, please let us know.
