IDS 4235 and CTR
ellwood.krobel
I have a few issues. The first is the auto update for automatically having policies being updated on the sensor. Does anyone have any problems getting the auto update to work? What is the site URL for this that you use? Also, the CTR access from client SSL is slow. Where is the CTR software 2.0.1 that fixes this? Also, I get a hostname mismatch but believe I have to reload my Certificate now that I have the proper name in the hostname file of the CTR Server. Does that sound correct?
umedryk
Level 5
Level 5
If you are a registered customer, you can download the software from cisco.com
