IDS4.0 RDEP / IDIOM SDK
jbarlow
Are there SDK's available for IDIOM and/or RDEP for the IDS4.0?
5 Replies 5
pcomeaux
Yes. The SDK is available below. Please keep in mind, the SDK is a set of specifications, not software.
http://www.cisco.com/cgi-bin/dev_support/access_level/products.cgi?product=IDS_INT_API
While that URL does point to the RDEP specification, it doesn't seem to point to the IDIOM specification referenced by that RDEP spec. Is the IDIOM spec currently available?
IDIOM is not yet available on CCO. It is in the review process. Should be there in a few weeks.
yatin
1 : Is there a release date for the IDIOM spec?
2 : Has the link to the RDEP SDK been changed?
