Increase https rsa key on 3850
julio.aldana
Frequent Visitor
Frequent Visitor
When you enable http secure server on a cisco device, it generates 1024 rsa keys. Is it possible to generate 2048 bits keys for https? I don't want to request an authority certificate.
We want to do this on a 3850 switch with 3.3.4SE IOS.
You can generate an extra RSA-keypair for that:
crypto key generate rsa label HTTPS-KEY modulus 2048
crypto pki trustpoint YOUR-TRUSTPOINT
  rsakeypair HTTPS-KEY
ip http secure-trustpoint YOUR-TRUSTPOINT
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Thanks Karsten
Can I configure a trustpoint with just a switch? I mean no servers, official certification entities, applications.... just commands on one single switch?.
Thanks for you help.
Oh... now I understand you included the trustpoint configuration. Sorry >.<
Thanks again.
