Installation procedure for Cisco Works
melangnghe
We need to write a Cisco Works (IDS MC) installation documentation. Is there a written procedure from Cisco as we can't find it.
TIA.
pcomeaux
There's this document:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/mgt_ids/idsmc12/ig/index.htm
titled: Installing, Upgrading, and Uninstalling IDS MC and Security Monitor on Windows
but there is more to it to get IDS MC installed from scratch.
Are you familiar with the above link?
The basic procedure I use is:
1) Intall W2k with SP4 on server meeting specs
2) Install Common Services
3) Install patches from install CD (autorun installs these)
4) Install Update 1
5) Install IDS MC
6) Install Patches for IDS MC
7) Install Signature Updates
8) Add sensors and tune
There's more details to each step, like where to find the files, etc.
Tell us more about the details you want and we can try to see what exists.
peter
How about detailed instructions on Solaris installation with troubleshooting steps for when the installation proceedur listed above fails?
Not having installed it on Solaris, let's hope someone else can help or start a new post. The above procedures should still apply, except the Windows related SP4 and updates to the OS.
In the above link, there's a chapter on Installation on Solaris - Installing, Upgrading, and Uninstalling IDS MC and Security Monitor on Solaris - http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/mgt_ids/idsmc12/ig/ch03.htm
As far as using and troubleshooting, I would refer to the Using Management Center for IDS Sensors 1.2 http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/mgt_ids/idsmc12/ug/index.htm
In this chapter, there are several more chapters that can help with Tuning, Troubleshooting, etc.
Hope this helps,
peter
