IP Spoofing
travis-dennis_2
Level 7
Level 7
I know it is very easy to spoof an IP address from the outside of a network. How hard is it to spoof a MAC address or when you spoof the IP address are you spoofing the MAC address as well? I want to set up my 3524 switches to only allow specified MAC addresses through. The logistics are not a problem as we are a smaller company. I want to know would I be wasting my time gathering the MAC addresses and putting them in the switches if the MAC addresses can be as easily spoofed as an IP address.
jbaigorr
From my experience, MAC address spoofing can be done. I've seen it done mostly in cable environments.
If possible, create access-list on your router with known spoofed ip's. It might be easier than gathering all your MACs on your network.
Cheers,
Gonzalo
