IPSEC Keyring Not Working With Supernet Address
beacra
I am working on a DMVPN design with IPSEC.
But i am having issues with the Keyring / ISAKMP Profile
If I have:
crypto keyring TEST
pre-shared-key address 10.0.0.0 255.0.0.0 key TESTKEY
crypto isakmp profile TEST
keyring TEST
match identity address 10.0.0.0 255.0.0.0
local-address Lo0
crypto ipsec profile TEST
set-transform TEST
set pfs group14
set isakmp-profile TEST
it doesnt work, I keep seeing "fail_class_cnt:1"
But if I change it to a more specific:
crypto keyring TEST
pre-shared-key address 10.1.1.0 255.255.255.252 key TESTKEY
keyring TEST
match identity address 10.1.1.0 255.255.255.252
local-address Lo0
set-transform TEST
set pfs group14
It will work just fine,
but my range of addresses makes it a nuissance to do specific addresses for each one, I really want them to all be able to be grouped into a supernet address / key
Is there something I am missing here?
Does it just not like the 10.0.0.0/8 ?
edit: i have omitted the extra code as I don't think its necessary, but consider that the local address is 10.150.1.1 for example and remote (spoke) is 10.1.1.1
Philip D'Ath
Are you sure there is not another entry that might be matching instead?
Personally - I think it is easier using a certificate based deployment. Then you don't match on IP addresses at all.
https://www.cisco.com/c/en/us/support/docs/security/dynamic-multipoint-vpn-dmvpn/117688-config-dmvpn-00.html
Nah no other matching entry, in this instance there is a different ipsec/isakmp profile and keyring that has specific matches, but that profile is not applied to this tunnel, only the entries i've specified above.
I was wondering if something was going wrong that it was also referencing the other keyring/profile
however, since its all specified it shouldnt even look at that.
Very strange :/
