Iron S370 compatibility with Horizon 7 VDI
alim1
 I'm asking if there is a compatibility between cisco proxy Ironport S370 and the horizon 7 Virtual Desktop Infrastructure.
As i know that VDI rely on User-ID instead of user IP Address. So how can Ironport deal with the VDI solution? What are the problem that i may face if i integrate both solutions.
5 Replies 5
balaji.bandi
So the user login  to VDI, you want to use WSA as proxy ?
if understand correctly then it uses your internet settings as per your environment as proxy.
but look some of do not like as expected, we had some issues we need to bypass from proxy to work as expected.
https://kb.vmware.com/s/article/1009238
BB
Hello , thank you for your reply.
As i know that VDI rely on User-ID in authentication and user permission. Does IRON S370 accept User-ID? Does the rules rely on User-ID also?
where is this User-ID source from ?
BB
It's from Active Directory
in that case you can do AD integration with WSA. So WSA understand the users, while deploying access polices.
BB
