Is the switch span tx and recv needed for a 4230 sensor?
dlac455
Please help settle a debate we are having in my shop:
I say I need both the tx and rcv options on the VLAN span that my 4230 is attached to .
My coworker argues that only the rcv option is needed.
Would anyone like to weigh in?
marcabal
Depends entirely on your setup and span configuration.
Here are some examples of what I have experienced.
The sensor needs to see both the packets going from the client to the server (Machine A -> Machine B), as well as the responses from the server to the client (Machine B -> Machine A) in order to monitor correctly.
Where possible you want to prevent the duplication of packets.
NOTE: A vlan span is technically a port span of all ports in the vlan. So even though you configure it as a Vlan span you need to think of it as a port span. That is whay I base the results off of ports in my example below.
BASIC SETUP:
Machine A --->port 4/1 Switch Vlan 10 port 5/1 -----> Machine B
A both (tx+rx) span of vlan 10 will result in duplicate packets:
A->B packets will be captured as rx packets on 4/1 and tx packets on 5/1
B->A packets will be captured as rx packets on 5/1 and tx packets on 4/1
A rx span of vlan 10 will result in a single copy of each packet:
B->A packets will be captured as tx packets on 5/1
A tx span of vlan 10 will result in a single copy of each packet:
A->B packets will be captured as tx packets on 5/1
B->A packets will be captured as tx packets on 4/1
A both span of both ports 4/1 and 5/1 will result in duplicate packets:
A rx span of both ports 4/1 and 5/1 will result single copy of each packet:
A tx span of both ports 4/1 and 5/1 will result in single copy of each packet:
A both (tx+rx) span of just port 4/1 will result in a single copy of each packet:
MSFC ROUTING SETUP:
Machine A --->port 4/1 Switch Vlan 10 --> MSFC --> vlan 20 port 5/1 -----> Machine B
The MSFC changes things because it does not always participate in span sessions. The first few packets in a stream will go to the MSFC port and might be picked up by span, but additional packets in the stream will be fast switched (routed in sup hardware and not sent to MSFC in order to increase routing performance) so a span against the MSFC port won't see them. This is because even a vlan span is a span of the ports, so with the MSFC the initial packets going to the MSFC may be spanned, but fastswitched packets don't go to the MSFC port so must be spanned on the other ports.
A both (tx+rx) span of vlan 10 will result in some duplicate and some single copies of each packet:
Initial A->B packets captured as rx packets on 4/1 and tx packets on MSFC
Additional A->B packets captured as rx packets on 4/1 only
Initial B->A packets captured as rx packets on MSFC and tx packets on 4/1
Additional B->A packets captured as tx packets on 4/1 only
A rx span of vlan 10 will result in a single copy of some packets and no copies of others:
Initial B->A packets will be captured as rx packets on MSFC
Additional B-A packets will not be captured because of fast switching
A tx span of vlan 10 will result in a single copy of some packets and no copies of others:
Initial A->B packets will be captured as tx packets on MSFC
Additonal A->B packets will not be captured
B->A packets will be captured as tx packets on 4/1.
The following examples you will see are still the same with or without the MSFC involved:
