03-12-2003 05:08 AM - edited 03-09-2019 02:28 AM
we have two cisco vpn concentrator's (3005).
Behind one we use 172.20.167.0/24 (headquarters office)
Behind one we use 172.20.184.0/24 (remote office)
we are attemping to do a lan-to-lan tunnel, the tunnel establishes no problem,
the only problem is I can only ping the inside interface of the
headquarters concentrator . I cannot ping (or otherwise
communicate to) any hosts
on either subnet...
Solved! Go to Solution.
03-12-2003 05:21 AM
On either side, you need to ensure that all of your hosts know that the route to the other network is via the local concentrator, either using static routes on each host, or by adding the appropriate routing on whichever device is your default gateway.
03-12-2003 05:21 AM
03-12-2003 05:41 AM
Thanks for reply,
When I trace a route of inside interface of concentrator from connected site,Its shows that my trafic goes first toward concentrator (hop1) and then to second concentrator ((hop2)
C:\>tracert 172.20.x.9
Tracing route to 172.20.x.9 over a maximum of 30 hops
1 <10 ms <10 ms <10 ms 172.20.x.9
2 90 ms 90 ms 90 ms 172.20.x.9
Trace complete.
C:\>
