03-19-2001 08:24 AM - edited 03-08-2019 08:05 PM
i have two vlan on my switch which has layer 3 module.i have built two subinterfaces for connecting
these two vlans through inter vlan routing.
but i can not ping from one vlan to other side
without having route add on my windows 98 on both side.
how can i see another vlan without add command in
my windows
03-21-2001 08:38 AM
The focus of this board is Virtual Private Networks, however, there are a number of professionals online who may be able to assist you.
We are always considering additional forums for such topics and I will make a note of your post.
If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
03-23-2001 07:57 AM
What are you using to do inter vlan routing. A router or some MSFC card?
Can you ping from the one router interface to other.
If you can tell me wha texactly you are doing, i prob can help u
04-05-2001 02:24 PM
You need to configure routing between your VLANs. Take a look at http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/inst_nts/78_10164.htm#24106
