Load balancer connect to DMZ1
wkim
I have foundry load balancer that I am going to connect to my pix 520's dmz port.
Because, I have many VIPs that need public IP address, I was wondering if I can make multiple:
Static (dmz1, outside) commands.
(for example)
static (dmz1, outside) 204.31.17.5 10.1.1.2
static (dmz1, outside) 204.31.17.6 10.1.1.3
static (dmz1, outside) 204.31.17.7 10.1.1.4
static (dmz1, outside) 204.31.17.8 10.1.1.5
static (dmz1, outside) 204.31.17.9 10.1.1.6
conduits permit tcp host 204.31.17.5 eq www any
conduits permit tcp host 204.31.17.6 eq www any
conduits permit tcp host 204.31.17.7 eq www any
conduits permit tcp host 204.31.17.8 eq www any
conduits permit tcp host 204.31.17.9 eq www any
Probably have 50 more VIPs to add onto the pix box.
I have not run the configuration yet.
Each VIPs need one to one translation.
William
j-leadford
You can do it that way and it would work or you could create one static entry for all of them i.e.:
static (dmz1,outside) 204.31.17.1 10.1.1.1 netmask 255.255.255.255
This command will create a one to one static of 204.31.17.5 to 10.1.1.5
Then just create an access list for 204.31.17.1 to permit whatever ports you want to allow through.
