Logging buffer - How Big ?
stuart.jones
Can anyone tell me how you determine the size of the local logging buffer on a Pix, i have not been able to find this out, so any help would be really appreciated.
Stu
fzamora
Currently the logging buffer size is fixed to 4K.
Check the following:
CSCdv91497
Headline logging buffer should be configurable
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCdv91497&Submit=Search
I hope it helps
Franco Zamora
fzamora
CSCdv91497
I hope it helps
Franco Zamora
Franco
Thats great thanks so much for the help.
Stu
