Lower security interface to Higher Security interface
idodd
Community Member
Has anyone got example config on how to pass traffic from a lower security interface (15) to the Inside interface (100), I have tried a number of config's however they all seem to remove the implicit outbound rule which then stops all my customers working.
Many thanks
johnbroadway
Level 3
Level 3
I usualy set up a static address translation between the interfaces and then use a conduit or access list to permit the traffic, e.g.
static (dmz,outside) 192.202.100.133 10.20.100.133 netmask 255.255.255.255 0 0
conduit permit tcp host 192.202.100.133 eq smtp any
Hope that helps
John
John,
I'll give it a whirl thanks
