07-19-2012 03:48 AM - edited 03-09-2019 11:52 PM
I'm trying to configure MAB on a Cisco 3560G to work with FreeRADIUS.
I have been assured that my RADIUS configuration is fine and the server is functioning properly.
This is my current switch config:
Header 1 |
! version 12.2 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Switch ! boot-start-marker boot-end-marker ! logging file flash:mab.txt 256000 debugging enable password admin ! username admin privilege 15 password 0 admin ! ! aaa new-model ! ! aaa group server radius test server 10.0.0.90 auth-port 1812 acct-port 1813 ! aaa authentication dot1x default group radius aaa authorization network default group radius aaa accounting delay-start aaa accounting dot1x default start-stop group radius aaa accounting dot1x system start-stop group radius aaa accounting network default start-stop group radius ! ! ! aaa session-id common system mtu routing 1500 authentication mac-move permit mab request format attribute 32 vlan access-vlan ip subnet-zero ! ip dhcp pool dpool1 network 10.0.0.0 255.255.255.0 ! ip dhcp pool dpool20 network 10.10.10.0 255.255.255.0 default-router 10.10.10.1 ! ! ! ! crypto pki trustpoint TP-self-signed-2405477248 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-2405477248 revocation-check none rsakeypair TP-self-signed-2405477248 ! ! crypto pki certificate chain TP-self-signed-2405477248 certificate self-signed 01 nvram:IOS-Self-Sig#3838.cer dot1x system-auth-control ! ! ! archive log config logging enable spanning-tree mode pvst spanning-tree etherchannel guard misconfig spanning-tree extend system-id ! vlan internal allocation policy ascending ! ! ! ! interface GigabitEthernet0/1 switchport mode access spanning-tree portfast ! interface GigabitEthernet0/2 ! interface GigabitEthernet0/3 ! interface GigabitEthernet0/4 ! interface GigabitEthernet0/5 ! interface GigabitEthernet0/6 ! interface GigabitEthernet0/7 ! interface GigabitEthernet0/8 ! interface GigabitEthernet0/9 ! interface GigabitEthernet0/10 ! interface GigabitEthernet0/11 ! interface GigabitEthernet0/12 ! interface GigabitEthernet0/13 switchport mode access authentication event server alive action reinitialize authentication open authentication order mab authentication priority mab authentication port-control auto authentication timer reauthenticate 10 authentication timer inactivity 1200 mab dot1x pae authenticator dot1x timeout tx-period 6 spanning-tree portfast ! interface GigabitEthernet0/14 ! interface GigabitEthernet0/15 ! interface GigabitEthernet0/16 ! interface GigabitEthernet0/17 ! interface GigabitEthernet0/18 ! interface GigabitEthernet0/19 ! interface GigabitEthernet0/20 ! interface GigabitEthernet0/21 ! interface GigabitEthernet0/22 ! interface GigabitEthernet0/23 ! interface GigabitEthernet0/24 ! interface GigabitEthernet0/25 ! interface GigabitEthernet0/26 ! interface GigabitEthernet0/27 ! interface GigabitEthernet0/28 ! interface Vlan1 ip address 10.0.0.1 255.255.255.0 ! interface Vlan20 ip address 10.10.10.1 255.255.255.0 ! ip classless ip http server ip http secure-server ! ! ip radius source-interface Vlan1 ip sla enable reaction-alerts ! radius-server dead-criteria time 30 tries 3 radius-server host 10.0.0.90 auth-port 1812 acct-port 1813 non-standard key pass radius-server retransmit 6 radius-server timeout 10 radius-server vsa send accounting radius-server vsa send authentication ! ! line con 0 logging synchronous line vty 0 4 transport input telnet line vty 5 15 transport input telnet ! end |
These are the errors I'm getting:
Header 1 |
*Mar 1 04:22:37.194: %MAB-5-FAIL: Authentication failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:22:37.194: %AUTHMGR-7-RESULT: Authentication result 'server dead' from 'mab' for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:22:37.194: %AUTHMGR-5-FAIL: Authorization failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:23:38.053: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.0.0.90:1812,1813 is not responding. *Mar 1 04:23:38.062: %MAB-5-FAIL: Authentication failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:23:38.062: %AUTHMGR-7-RESULT: Authentication result 'server dead' from 'mab' for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:23:38.062: %AUTHMGR-5-FAIL: Authorization failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:23:38.062: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.0.0.90:1812,1813 is being marked alive. *Mar 1 04:23:44.412: %SYS-5-CONFIG_I: Configured from console by console *Mar 1 04:24:38.778: mab-ev(Gi0/13): Reauthenticating client 0x31000001 (0015.c553.7baa) *Mar 1 04:24:38.778: mab-sm(Gi0/13): Received event 'MAB_REAUTHENTICATE' on handle 0x31000001 *Mar 1 04:24:38.778: mab : during state mab_terminate, got event 2(mabReauthenticate) *Mar 1 04:24:38.778: @@@ mab : mab_terminate -> mab_authorizing *Mar 1 04:24:38.778: mab-ev(Gi0/13): Sending create new context event to EAP from MAB for 0x31000001 (0015.c553.7baa) *Mar 1 04:24:38.778: mab-ev(Gi0/13): Starting MAC-AUTH-BYPASS for 0x31000001 (0015.c553.7baa) *Mar 1 04:24:38.778: mab-ev(Gi0/13): Attribute (NAS-Identifier) value 1 received for 0x31000001 (0015.c553.7baa) *Mar 1 04:24:38.778: RADIUS/ENCODE(00000009):Orig. component type = DOT1X *Mar 1 04:24:38.778: RADIUS(00000009): Config NAS IP: 10.0.0.1 *Mar 1 04:24:38.778: RADIUS(00000009): Started 10 sec timeout *Mar 1 04:24:38.988: RADIUS: Received from id 1645/250 10.0.0.90:1812, Access-Accept, len 42 *Mar 1 04:24:38.988: RADIUS/DECODE: Ascend auth type; FAIL *Mar 1 04:24:38.988: RADIUS/DECODE: decoder; FAIL *Mar 1 04:24:38.988: RADIUS/DECODE: attribute Ascend-Auth-Type; FAIL *Mar 1 04:24:38.988: RADIUS/DECODE: parse response op decode; FAIL *Mar 1 04:24:38.988: RADIUS/DECODE: parse response; FAIL *Mar 1 04:24:38.988: mab-ev(Gi0/13): MAB received an Access-Reject for 0x31000001 (0015.c553.7baa) *Mar 1 04:24:38.988: %MAB-5-FAIL: Authentication failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:24:38.988: mab-sm(Gi0/13): Received event 'MAB_RESULT' on handle 0x31000001 *Mar 1 04:24:38.996: mab : during state mab_authorizing, got event 5(mabResult) *Mar 1 04:24:38.996: @@@ mab : mab_authorizing -> mab_terminate *Mar 1 04:24:38.996: mab-ev(Gi0/13): Deleted credentials profile for 0x31000001 (dot1x_mac_auth_0015c5537baa) *Mar 1 04:24:38.996: mab-ev(Gi0/13): Sending event (2) to AuthMGR for 0015.c553.7baa *Mar 1 04:24:38.996: %AUTHMGR-7-RESULT: Authentication result 'server dead' from 'mab' for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:24:38.996: %AUTHMGR-5-FAIL: Authorization failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:25:39.730: mab-ev(Gi0/13): Reauthenticating client 0x31000001 (0015.c553.7baa) *Mar 1 04:25:39.730: mab-sm(Gi0/13): Received event 'MAB_REAUTHENTICATE' on handle 0x31000001 *Mar 1 04:25:39.730: mab : during state mab_terminate, got event 2(mabReauthenticate) *Mar 1 04:25:39.730: @@@ mab : mab_terminate -> mab_authorizing *Mar 1 04:25:39.730: mab-ev(Gi0/13): Sending create new context event to EAP from MAB for 0x31000001 (0015.c553.7baa) *Mar 1 04:25:39.730: mab-ev(Gi0/13): Starting MAC-AUTH-BYPASS for 0x31000001 (0015.c553.7baa) *Mar 1 04:25:39.730: mab-ev(Gi0/13): Attribute (NAS-Identifier) value 1 received for 0x31000001 (0015.c553.7baa) *Mar 1 04:25:39.730: RADIUS/ENCODE(00000009):Orig. component type = DOT1X *Mar 1 04:25:39.730: RADIUS(00000009): Config NAS IP: 10.0.0.1 *Mar 1 04:25:39.730: RADIUS(00000009): Started 10 sec timeout *Mar 1 04:25:39.747: RADIUS: Received from id 1645/251 10.0.0.90:1812, Access-Accept, len 42 *Mar 1 04:25:39.747: RADIUS/DECODE: Ascend auth type; FAIL *Mar 1 04:25:39.747: RADIUS/DECODE: decoder; FAIL *Mar 1 04:25:39.747: RADIUS/DECODE: attribute Ascend-Auth-Type; FAIL *Mar 1 04:25:39.747: RADIUS/DECODE: parse response op decode; FAIL *Mar 1 04:25:39.747: RADIUS/DECODE: parse response; FAIL *Mar 1 04:25:39.747: mab-ev(Gi0/13): MAB received an Access-Reject for 0x31000001 (0015.c553.7baa) *Mar 1 04:25:39.747: %MAB-5-FAIL: Authentication failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:25:39.747: mab-sm(Gi0/13): Received event 'MAB_RESULT' on handle 0x31000001 *Mar 1 04:25:39.747: mab : during state mab_authorizing, got event 5(mabResult) *Mar 1 04:25:39.747: @@@ mab : mab_authorizing -> mab_terminate *Mar 1 04:25:39.747: mab-ev(Gi0/13): Deleted credentials profile for 0x31000001 (dot1x_mac_auth_0015c5537baa) *Mar 1 04:25:39.755: mab-ev(Gi0/13): Sending event (2) to AuthMGR for 0015.c553.7baa *Mar 1 04:25:39.755: %AUTHMGR-7-RESULT: Authentication result 'server dead' from 'mab' for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:25:39.755: %AUTHMGR-5-FAIL: Authorization failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:26:40.472: mab-ev(Gi0/13): Reauthenticating client 0x31000001 (0015.c553.7baa) *Mar 1 04:26:40.472: mab-sm(Gi0/13): Received event 'MAB_REAUTHENTICATE' on handle 0x31000001 *Mar 1 04:26:40.472: mab : during state mab_terminate, got event 2(mabReauthenticate) *Mar 1 04:26:40.472: @@@ mab : mab_terminate -> mab_authorizing *Mar 1 04:26:40.472: mab-ev(Gi0/13): Sending create new context event to EAP from MAB for 0x31000001 (0015.c553.7baa) *Mar 1 04:26:40.472: mab-ev(Gi0/13): Starting MAC-AUTH-BYPASS for 0x31000001 (0015.c553.7baa) *Mar 1 04:26:40.472: mab-ev(Gi0/13): Attribute (NAS-Identifier) value 1 received for 0x31000001 (0015.c553.7baa) *Mar 1 04:26:40.472: RADIUS/ENCODE(00000009):Orig. component type = DOT1X *Mar 1 04:26:40.472: RADIUS(00000009): Config NAS IP: 10.0.0.1 *Mar 1 04:26:40.472: RADIUS(00000009): Started 10 sec timeout *Mar 1 04:26:40.489: RADIUS: Received from id 1645/252 10.0.0.90:1812, Access-Accept, len 42 *Mar 1 04:26:40.489: RADIUS/DECODE: Ascend auth type; FAIL *Mar 1 04:26:40.489: RADIUS/DECODE: decoder; FAIL *Mar 1 04:26:40.489: RADIUS/DECODE: attribute Ascend-Auth-Type; FAIL *Mar 1 04:26:40.489: RADIUS/DECODE: parse response op decode; FAIL *Mar 1 04:26:40.489: RADIUS/DECODE: parse response; FAIL *Mar 1 04:26:40.489: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.0.0.90:1812,1813 is not responding. *Mar 1 04:26:40.489: mab-ev(Gi0/13): MAB received an Access-Reject for 0x31000001 (0015.c553.7baa) *Mar 1 04:26:40.489: %MAB-5-FAIL: Authentication failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:26:40.489: mab-sm(Gi0/13): Received event 'MAB_RESULT' on handle 0x31000001 *Mar 1 04:26:40.489: mab : during state mab_authorizing, got event 5(mabResult) *Mar 1 04:26:40.489: @@@ mab : mab_authorizing -> mab_terminate *Mar 1 04:26:40.489: mab-ev(Gi0/13): Deleted credentials profile for 0x31000001 (dot1x_mac_auth_0015c5537baa) *Mar 1 04:26:40.489: mab-ev(Gi0/13): Sending event (2) to AuthMGR for 0015.c553.7baa *Mar 1 04:26:40.489: %AUTHMGR-7-RESULT: Authentication result 'server dead' from 'mab' for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:26:40.489: %AUTHMGR-5-FAIL: Authorization failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:26:40.547: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.0.0.90:1812,1813 is being marked alive. *Mar 1 04:27:41.197: mab-ev(Gi0/13): Reauthenticating client 0x31000001 (0015.c553.7baa) *Mar 1 04:27:41.197: mab-sm(Gi0/13): Received event 'MAB_REAUTHENTICATE' on handle 0x31000001 *Mar 1 04:27:41.197: mab : during state mab_terminate, got event 2(mabReauthenticate) *Mar 1 04:27:41.197: @@@ mab : mab_terminate -> mab_authorizing *Mar 1 04:27:41.197: mab-ev(Gi0/13): Sending create new context event to EAP from MAB for 0x31000001 (0015.c553.7baa) *Mar 1 04:27:41.197: mab-ev(Gi0/13): Starting MAC-AUTH-BYPASS for 0x31000001 (0015.c553.7baa) *Mar 1 04:27:41.197: mab-ev(Gi0/13): Attribute (NAS-Identifier) value 1 received for 0x31000001 (0015.c553.7baa) *Mar 1 04:27:41.197: RADIUS/ENCODE(00000009):Orig. component type = DOT1X *Mar 1 04:27:41.197: RADIUS(00000009): Config NAS IP: 10.0.0.1 *Mar 1 04:27:41.197: RADIUS(00000009): Started 10 sec timeout *Mar 1 04:27:41.214: RADIUS: Received from id 1645/253 10.0.0.90:1812, Access-Accept, len 42 *Mar 1 04:27:41.214: RADIUS/DECODE: Ascend auth type; FAIL *Mar 1 04:27:41.214: RADIUS/DECODE: decoder; FAIL *Mar 1 04:27:41.214: RADIUS/DECODE: attribute Ascend-Auth-Type; FAIL *Mar 1 04:27:41.214: RADIUS/DECODE: parse response op decode; FAIL *Mar 1 04:27:41.214: RADIUS/DECODE: parse response; FAIL *Mar 1 04:27:41.214: mab-ev(Gi0/13): MAB received an Access-Reject for 0x31000001 (0015.c553.7baa) *Mar 1 04:27:41.214: %MAB-5-FAIL: Authentication failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:27:41.214: mab-sm(Gi0/13): Received event 'MAB_RESULT' on handle 0x31000001 *Mar 1 04:27:41.214: mab : during state mab_authorizing, got event 5(mabResult) *Mar 1 04:27:41.214: @@@ mab : mab_authorizing -> mab_terminate *Mar 1 04:27:41.214: mab-ev(Gi0/13): Deleted credentials profile for 0x31000001 (dot1x_mac_auth_0015c5537baa) *Mar 1 04:27:41.214: mab-ev(Gi0/13): Sending event (2) to AuthMGR for 0015.c553.7baa *Mar 1 04:27:41.214: %AUTHMGR-7-RESULT: Authentication result 'server dead' from 'mab' for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:27:41.214: %AUTHMGR-5-FAIL: Authorization failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:28:41.922: mab-ev(Gi0/13): Reauthenticating client 0x31000001 (0015.c553.7baa) *Mar 1 04:28:41.922: mab-sm(Gi0/13): Received event 'MAB_REAUTHENTICATE' on handle 0x31000001 *Mar 1 04:28:41.922: mab : during state mab_terminate, got event 2(mabReauthenticate) *Mar 1 04:28:41.922: @@@ mab : mab_terminate -> mab_authorizing *Mar 1 04:28:41.922: mab-ev(Gi0/13): Sending create new context event to EAP from MAB for 0x31000001 (0015.c553.7baa) *Mar 1 04:28:41.922: mab-ev(Gi0/13): Starting MAC-AUTH-BYPASS for 0x31000001 (0015.c553.7baa) *Mar 1 04:28:41.922: mab-ev(Gi0/13): Attribute (NAS-Identifier) value 1 received for 0x31000001 (0015.c553.7baa) *Mar 1 04:28:41.922: RADIUS/ENCODE(00000009):Orig. component type = DOT1X *Mar 1 04:28:41.922: RADIUS(00000009): Config NAS IP: 10.0.0.1 *Mar 1 04:28:41.922: RADIUS(00000009): Started 10 sec timeout *Mar 1 04:28:41.939: RADIUS: Received from id 1645/254 10.0.0.90:1812, Access-Accept, len 42 *Mar 1 04:28:41.939: RADIUS/DECODE: Ascend auth type; FAIL *Mar 1 04:28:41.939: RADIUS/DECODE: decoder; FAIL *Mar 1 04:28:41.939: RADIUS/DECODE: attribute Ascend-Auth-Type; FAIL *Mar 1 04:28:41.939: RADIUS/DECODE: parse response op decode; FAIL *Mar 1 04:28:41.939: RADIUS/DECODE: parse response; FAIL *Mar 1 04:28:41.939: mab-ev(Gi0/13): MAB received an Access-Reject for 0x31000001 (0015.c553.7baa) *Mar 1 04:28:41.947: %MAB-5-FAIL: Authentication failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:28:41.947: mab-sm(Gi0/13): Received event 'MAB_RESULT' on handle 0x31000001 *Mar 1 04:28:41.947: mab : during state mab_authorizing, got event 5(mabResult) *Mar 1 04:28:41.947: @@@ mab : mab_authorizing -> mab_terminate *Mar 1 04:28:41.947: mab-ev(Gi0/13): Deleted credentials profile for 0x31000001 (dot1x_mac_auth_0015c5537baa) *Mar 1 04:28:41.947: mab-ev(Gi0/13): Sending event (2) to AuthMGR for 0015.c553.7baa *Mar 1 04:28:41.947: %AUTHMGR-7-RESULT: Authentication result 'server dead' from 'mab' for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:28:41.947: %AUTHMGR-5-FAIL: Authorization failed for client (0015.c553.7baa) on Interface Gi0/13 AuditSessionID 0A0000010000000100DEC072 *Mar 1 04:29:42.052: dot1x-ev(Gi0/13): Interface state changed to DOWN *Mar 1 04:29:42.052: dot1x-ev:dot1x_supp_port_down: No DOT1X subblock found on GigabitEthernet0/13 *Mar 1 04:29:42.052: mab-sm(Gi0/13): Received event 'MAB_DELETE' on handle 0x31000001 *Mar 1 04:29:42.052: mab-ev(Gi0/13): Received ABORT event from Auth Mgr for 0x31000001 (0015.c553.7baa) *Mar 1 04:29:42.052: mab-ev(Gi0/13): Deleted credentials profile for 0x31000001 (dot1x_mac_auth_0015c5537baa) *Mar 1 04:29:42.052: mab-ev: Freed MAB client context *Mar 1 04:29:43.050: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down *Mar 1 04:29:44.048: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down *Mar 1 04:29:49.274: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to up *Mar 1 04:29:50.281: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to up |
Since I have never used RADIUS before on a Cisco device I am really not sure where the issue is.
Can anybody help me?
Thanks.
07-19-2012 03:52 AM
Sorry I missed a part.
Basically what I have is a Linux server running FreeRADIUS, a Cisco 3560G switch and a laptop.
The setup is to replace VMPS as a way of distributing VLANs throughout the network dynamically.
Currently I would like the server to automatically distribute VLAN20 to the switch to use on interface g0/13.
07-19-2012 11:11 AM
I managed to find a solution to this and get things working:
Header 1 |
! version 12.2 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Switch ! boot-start-marker boot-end-marker ! ! ! ! aaa new-model ! ! aaa authentication dot1x default group radius aaa authorization network default group radius ! ! ! aaa session-id common system mtu routing 1500 authentication mac-move permit ip subnet-zero ! ip dhcp pool dpool1 network 10.0.0.0 255.255.255.0 ! ip dhcp pool dpool20 network 10.10.10.0 255.255.255.0 default-router 10.10.10.1 ! ! ! ! ! dot1x system-auth-control ! ! ! spanning-tree mode pvst spanning-tree etherchannel guard misconfig spanning-tree extend system-id ! vlan internal allocation policy ascending ! ! ! ! interface GigabitEthernet0/1 switchport mode access spanning-tree portfast ! interface GigabitEthernet0/2 ! interface GigabitEthernet0/3 ! interface GigabitEthernet0/4 ! interface GigabitEthernet0/5 ! interface GigabitEthernet0/6 ! interface GigabitEthernet0/7 ! interface GigabitEthernet0/8 ! interface GigabitEthernet0/9 ! interface GigabitEthernet0/10 ! interface GigabitEthernet0/11 ! interface GigabitEthernet0/12 ! interface GigabitEthernet0/13 switchport mode access authentication port-control auto mab spanning-tree portfast ! interface GigabitEthernet0/14 ! interface GigabitEthernet0/15 ! interface GigabitEthernet0/16 ! interface GigabitEthernet0/17 ! interface GigabitEthernet0/18 ! interface GigabitEthernet0/19 ! interface GigabitEthernet0/20 ! interface GigabitEthernet0/21 ! interface GigabitEthernet0/22 ! interface GigabitEthernet0/23 ! interface GigabitEthernet0/24 ! interface GigabitEthernet0/25 ! interface GigabitEthernet0/26 ! interface GigabitEthernet0/27 ! interface GigabitEthernet0/28 ! interface Vlan1 ip address 10.0.0.1 255.255.255.0 ! interface Vlan20 ip address 10.10.10.1 255.255.255.0 ! ip classless ip http server ip http secure-server ! ! ip sla enable reaction-alerts ! radius-server host 10.0.0.90 auth-port 1812 acct-port 1813 key pass ! ! line con 0 line vty 5 15 ! end |
Now the laptop is able to put straight onto VLAN20 and obtains the correct IP address of 10.10.10.0/24 range....
