Main Interface and Sub Interface
stevenmcnamara
I'm fairly new to ASA firewalls so some help is appreciated. Can anyone explain the point of the below config. I thought that normally when using Vlan's there would be no point on configuring a nameif & security level on the main interface? In this case what would configuring an ACL based NAT exemption on the Trunk interface do to traffic on the sub interfaces?
interface GigabitEthernet1/0
nameif Trunk
security-level 100
no ip address
interface GigabitEthernet1/0.100
vlan 100
nameif VLAN100
security-level 100
ip address 192.168.100.1 255.255.255.0 standby 192.168.100.2
interface GigabitEthernet1/0.101
vlan 101
nameif VLAN101
security-level 90
ip address 192.168.101.1 255.255.255.0 standby 192.168.101.2
interface GigabitEthernet1/0.102
vlan 102
nameif VLAN102
security-level 80
ip address 192.168.102.1 255.255.255.0 standby 192.168.102.2
Thanks Steve
Collin Clark
You're right about the main interface.
If you use subinterfaces, you typically do not also want the physical interface to pass traffic, because the physical interface passes untagged packets. Because the physical interface must be enabled for the subinterface to pass traffic, ensure that the physical interface does not pass traffic by leaving out the nameif command. If you want to let the physical interface pass untagged packets, you can configure the nameif command as usual.
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/intrface.html#wp1044006
Hope that helps
