map inbound tcp port 44444 to tcp port 443?
jim.brown
I have a problem with a customer who authenticates all of his outbound http and https traffic on a proxy. I need for our software to connect outbound from his network on tcp port 44444, and then map that tcp port to 443 on my network before is hits my servers. I have a PIX and a CSS 11051. I have not had any luck with either. Any suggestions?
cpembleton
Level 4
Level 4
You need a static pat entry.
Example:
host inside 10.0.0.1 port 443
host outside 65.10.10.10 port 4444
static (inside,outside) 65.10.10.10 4444 10.0.0.1 443 netmask
255.255.255.255
Hope this helps!
Chad
Please rate if this helps!
Not exactly. A static would look like:
static (inside,outside) tcp a.b.c.d 44444 w.x.y.z 443 netmask 255.255.255.255 0 0
where a.b.c.d is the external IP (or use interface if that's the external IP to use), and w.x.y.z is the translated IP.
Glen
