08-14-2007 09:11 AM - edited 03-09-2019 06:35 PM
here's the syntax from the MARS online help to run the CLI upgrade utility
pnupgrade http://10.1.1.1/package [user] [passwd]
works ok if using FTP and "package" is located in the root directory of the FTP server
trying to download and install an upgrade from a non-root subfolder and MARS complains.
is there some restriction on where the upgrade package resides on the source server?
thanks
-randy
08-21-2007 06:02 AM
Upgrade from CLI will work on
HTTPS, HTTP (TCP port 80), or FTP
At the command line, you can also upgrade from the DVD drive, which does not require any extra opened ports
08-21-2007 06:42 AM
thanks - I see the various protocol options but the issue here seems to be the upgrade (file) path - if I try to point MARS anywhere but the root (/) directory on the FTP server it does not work.
08-21-2007 07:07 AM
What type of FTP server are you employing for this upgrade?
I'm not ruling out it could be a MARS issue, or it may be your particular FTP server may only look in the root directory.
Be interested in hearing what you determine.
Hope this helps.
08-21-2007 07:46 AM
the ftp server is a product calledMoveIT-DMZ - which apparently supports FTP, HTTP, HTTPS, SCP, etc.
I also had the same problem with a freeware FTP server (WARftpdaemon) running on my laptop - upgrade works fine unless I put the upgrade files in some subdirectory.
