Microsoft Teams Call ACP Question
dcanady55
Level 3
Level 3
We are currently using Cisco 2110s, and it appears that Cisco still does not allow us to remediate elephant flows in the advanced section. The only way to reduce the impact seems to be by setting up a trust rule for specific traffic. Upon analyzing our elephant flows, it seems that many of them are caused by Teams calls. Is there any reason not to set up a trust rule specifically for the Teams Call application? Additionally, does anyone know if Cisco plans to enable remediation for elephant flows on 2110s in the future?
what version are you running ?
what are the threshold set for elephant flow remedation ? are you sure you are hitting those thresholds ?
https://secure.cisco.com/secure-firewall/docs/elephant-flow-throttling
TEams calls may use UDP and all of that is encrypted streams , and it is SRTP (secure rtp) which firepower doesnt really decrypt..  if you are not doing ssl decryption for teams/MS services traffic, then yes you could do fastpath pre-filter for that traffic or just the teams calls(if you can do based on UDP ports etc)... trust option will still use snort resources, so pre-filter is the best option to bypass SNORT..
Running 7.4.2.1 on 2110.
I don't have any thresholds setup for elephant flows because that feature is not available for 2110s. I thought Trust does not use snort as that's what the guide says.
Until Now Cisco not support this feature in 2110 as I know.
You must check release note of FTD ver.
MHM
Hi Yes i completely forgot about it. 21xx does not have it.. it can only detect elephant flows.
Your best best is to use pre-filter for now if it is really causing a performance issue.
this is the enhancement defect, and you can follow up with your Cisco account team or partner account team/SE for status..
https://quickview.cloudapps.cisco.com/quickview/bug/CSCwh17142
Although trust bypasses SNORT for the most part, the packet (pointer) is still sent to SNORT for lookup/ initial processing and it can be taxing. The most efficient way is to use pre-filter policy.
Hope that helps
**Please rate as helpful if this was useful**
