Mobile Device and installing certificate(s) to connect to ISE
sophon
Hi, I was wondering if anyone could advise or help me with what I am trying to do.  I have an Android mobile device and I would like to install a WIFI certificate(s) issued by an Active Directory CA located on a the same WIFI EAP lab network as my Cisco ISE.  With the certificate installed on the Android device, I would like to access the WIFI to the lab network and have it 802.1X authenticate and authorize.  Can someone help or point me in the right direction please?  I would so much appreciate the help.
Peter Koltl
Level 7
Level 7
Search for ‘Cisco BYOD deployment guide’ document and dual SSID solution.
Hi Peter, I'm just trying to set up an EAP-TLS using certificate(s) for a WIFI connection.  I think I set up everything correctly on the ISE side but on the Android mobile device side, I am unsure which certificate(s) to use.  I am using MS Active Directory CA for certificates.  Which certificates would I be using if I open certmgr window on the authentication server?  Do I need to export it with a private key?  Is there anything else that I need to know?
Do you already have the pkcs file to be imported into Android? or you want to enrol the certificate to Android automatically?
