mss on interface
dobner
Hello everybody,
snenario:
inside --- PIX 535 6.3(3)UR --- outside with ipsec tunnel endpoint
traffic from inside to outside was restricted to mss=1460. After configuring the tunnel it's now mss=1380, also for traffic not going into the tunnel. The tunnel seems to lower the mss by 80 bytes.
mtu is still set to default 1500 on all interfaces. Is it possible to get non-tunnel-traffic back to mss=1460 bytes?
Many thanks for all kinds of help
Uli
mmellet
Level 3
Level 3
Try changing the value using the command sysopt connection tcpmss.
