Nameif and IP commands doesn't apppear
sermelag
I have a PIX 515E and I can't use the nameif and ip commands. I'm with version 7.0(1) and device mangaer 5.0(1)
carl.fuller
Where you used to do it in global config mode, 7.0.1 now has similar router commands to go into interface mode:
pixfirewall(config)#interface Ethernet0
pixfirewall(config-if)#speed 100
pixfirewall(config-if)#duplex full
pixfirewall(config-if)#nameif outside
pixfirewall(config-if)#security-level 0
pixfirewall(config-if)#ip address 192.168.9.30 255.255.255.0
pixfirewall(config-if)#exit
pixfirewall(config)#interface Ethernet1
pixfirewall(config-if)#nameif inside
pixfirewall(config-if)#security-level 100
pixfirewall(config-if)#ip address 10.0.0.1 255.255.255.0
pixfirewall(config)#global (outside) 1 interface
pixfirewall(config)#nat (inside) 1 10.0.0.0 255.0.0.0
pixfirewall(config)#route outside 0.0.0.0 0.0.0.0 192.168.9.2 1
carl.fuller
