NAT DESIGN small ISSUE
r.kate
Hi ,
I have a PIX 515 and i have managed to set up a vpn with win2k over l2tp and ipsec .My Inside network say has the ip range of 10.200.1.x and the addresses given to vpn client are 10.200.25.xx .How can I allow the 10.208.25.xx clients to get access to the internet as if they were sitting in the office and working through the secure tunnel establish .
Raj
kagodfrey
Level 3
Level 3
AFAIK the pix only has a rudimentary routing capablitity, and does not allow the routing of a packet out of the same interface that it came in on. For this reason, you would also be unable to, say, contact the network on the other side of a pix-pix vpn tunnel when you vpn into one of those two pixes.
You could get around this if you have a proxy server on your internal network you can point your remote browsers at.
mklaphek
I don't think that this is quite what you're asking, but another option is to use a split-tunnel for this connection. This would allow you to have users connect to the inside and still surf the Internet.
