NEED CONFIGURATION HELP - Cisco 678 to a Cisco 806
kevino
Building a DSL-based VPN and one of the branch offices will access the Corporate network (Cisco 1720 head-end) via Cisco 806. The Cisco 806 will connect to a Cisco 678 DSL modem.
If anyone could provide me with the proper configuration information for all of the above devices, I'd very much appreciate it.
K. Owens
bbaley
Level 3
Level 3
Here’s a place to start: http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/secur_c/scprt4/scipsec.htm and here’s a sample config http://www.cisco.com/warp/public/707/25.shtml. More samples under “IPSEC using routers” from here: http://www.cisco.com/pcgi-bin/Support/PSP/psp_view.pl?p=Internetworking:IPSec&s=Implementation_and_Configuration. Keep in mind the 678 doesn’t support IPSEC so you’ll have to do this between regular IOS routers.
