Do i need to buy HA license for ASA5516-K9 or ASA5516-FPWR-BUN-K9?
or it comes built in.
Mitesh
Solved! Go to Solution.
Hello Mitesh-
HA comes with the base license for the 5516-X. Only the 5506 and the 5512 require the Security Plus license to get HA enabled. For more info please reference the following link:
I hope this helps!
Thank you for rating helpful posts!
Hello Mitesh-
I hope this helps!
Like Neno said for the base ASA.
Note that if you are using the FirePOWER module, those are licensed per unit - even in an HA pair.
So you would have to but the L-5516-<URL/TA/TAC/TAM/TAMC>-<1Y/3Y> as appropriate.
Below is my BOM, do I need to add License to both the device or the license quantity would be one fo both. I mean in HA mode.
ASA5516-FPWR-BUN | ASA 5516-X with FirePOWER Svcs. Chassis, Subs, FireSight Mgr | --- | N/A | 0.00 | 1 |
ASA5516-FPWR-K9 | ASA 5516-X with FirePOWER services, 8GE, AC, 3DES/AES | --- | 21 | 5,995.00 | 2 |
CON-SNT-ASA556F9 | SNTC-8X5XNBD ASA 5516-X with FirePOWER services, 8GE | 12 | N/A | 988.63 | 2 |
